Hi, Im new to this stuff and still learning, Im try to backup a dvd using Nero 5.5 but I keep getting the message "There is not enough space to burn this compilation onto this medium, Please insert another medium that provides more space." It dosnt matter which brand of dvd I try, I can not get past this message!
What it primarily means is that your file(s) won't fit on your disk. Some questions might be: 1) what format are you using, i.e. vcd, svcd, dvd: 2) how did you go about ripping the dvd; 3) what the size of you project in terms on mega or giga bytes? Right now there's not enough info for a complete answer. Nyah Levi
Hi, sorry Im just trying to copy straight from dvd to dvd, the dvd is 3.04gb and the blank dvd should be 4.7gb.
Trouble Burning on DVD Architect
By croonprince in forum Authoring (DVD)Replies: 0Last Post: 6th Dec 2011, 16:46 -
Burning DVDs trouble
By ssaamm in forum Newbie / General discussionsReplies: 8Last Post: 4th Aug 2009, 05:24 -
Is anybody having trouble burning semi-pro?
By mikes01 in forum DVD RippingReplies: 3Last Post: 12th Jun 2008, 19:18 -
trouble burning DVDs
By nick177th in forum DVD RippingReplies: 9Last Post: 5th Oct 2007, 16:10 -
Trouble burning/detecting DVD+R DL
By lowdirt in forum Authoring (DVD)Replies: 3Last Post: 21st Sep 2007, 02:23
