hi,
when i convert a vob into a avi or divx or whatever the sound will be extracted separated from the video!!! (demux)!! how can i play the avi with sound and in wich application (quick time)???
thx
I'd suggest trying Mencoder OSX, available here:
http://prdownloads.sourceforge.net/mplayerosx/mencoderrc077.sit?downloadI like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté." -
really?
What did you use to convert .vob to divx
when you say that was it just a sinlge .vob or a VIDEO_TS folder?
Quicktime doesnt handle divx very well unless you have lots of codex's installed and even then the audio usually doent work until you "doctor" the file with divx doctor or divx validator
just use a different media viewer like VLC or MplayerOSX
this is all assuming you did the conversoin properly.
Converting Divx to VOB - having problems.
By martinlest in forum Video ConversionReplies: 9Last Post: 6th Mar 2012, 17:23 -
vob/mpeg2 to Divx close to Dr Divx?
By Tiribulus in forum Video ConversionReplies: 8Last Post: 5th Dec 2009, 11:52 -
VOB to DivX using AviSynth8
By jieve in forum DVD RippingReplies: 58Last Post: 14th Aug 2009, 16:11 -
divx -> vob ?
By webking1 in forum Newbie / General discussionsReplies: 3Last Post: 25th Nov 2008, 12:50 -
Dr. DivX converts large VOB files into tiny unusable divX files
By texas1 in forum Newbie / General discussionsReplies: 2Last Post: 6th Aug 2007, 21:44
