im using TMPGEnc DVD Author to make menu for couple of movies im putting on the disc , i wonder if there is any menu author program that is a little bit better so i could later import her progject to TMPGEnc DVD Author which the menu edit there is not so advance ?
You can't make a menu in another DVD authoring program and then import the menu into TMPGEnc DVD Author.
You can make your own backgrounds for TMPGEnc DVD Author and with a bit of work you can make pretty decent menu designs.
The program works SO well in so MANY aspects that it is a bit of a shame that the MENU design is not better.
But to me the content is what really matters ... a menu is secondary.
If you really want to create more advanced menu designs then you might want to look into DVD-Lab
TMPGEnc DVD Author question/
By ingeborgdot in forum Authoring (DVD)Replies: 11Last Post: 22nd Sep 2008, 13:58 -
New TMPGEnc DVD Author Question
By Robert Simandl in forum Authoring (DVD)Replies: 1Last Post: 11th Jun 2008, 07:47 -
(Picture) Tmpgenc DVD Author 3 Question
By Maikeru-sama in forum Authoring (DVD)Replies: 0Last Post: 3rd May 2008, 18:20 -
TMPGEnc DVD Author 3 Question ...
By ZaYoOoD in forum Authoring (DVD)Replies: 5Last Post: 3rd Dec 2007, 07:17 -
By newtie in forum Authoring (DVD)Replies: 1Last Post: 4th Sep 2007, 09:49
