Hi, I captured from a digital camcorder to my hard disk using video studio 8.0 and installed the panasonic dv codec so I can edit it using other programs. The raw avi file came out to be 5gb, 25 minutes of video. I loaded up Tmpgenc 2.52 and proceeded to encode it to mpeg using the templates.
How come it takes almost 8 hours to encode 25 minutes of video to mpeg? I've captured from TV to raw avi (using a tv capture card) in the past and encoding it to mpeg doesn't take 7 hours for a 25 min. video. It took less than 2 hours to do so with the same settings for tmpgenc. But why does it take so long to encode the video that i got from the digital camcorder? Is it the DV codec? What else could I do to cut the time down? 8 hours encoding a 25 min is just ridiculous.![]()
The time difference could be codec related.
What codec did you use for your "raw avi" capture?
Most people confuse this, since almost nobody really uses "raw avi", as the file sizes would enormous (1.8 GIG per minute for the video only for NTSC). Also, since the DV coming from the camcoder is already DV encoded, it doesn't make sense to uncompress it.
MPEG encoding for DVD
By BraDave in forum AudioReplies: 4Last Post: 4th May 2011, 00:34 -
Please Help with converting AC3 in an AVI to an AVI with MPEG-1/MPEG-2
By twin1701 in forum Newbie / General discussionsReplies: 4Last Post: 13th Jul 2010, 15:11 -
Avi to MPEG-2 quality encoding mission
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 3Last Post: 31st Aug 2009, 02:10 -
Strange problem between AVI(mpeg) file and DVD based on AVI(mpeg) file
By 1234567 in forum DVD RippingReplies: 49Last Post: 15th Feb 2009, 08:36 -
MPEG editing without re-encoding
By AlanD in forum EditingReplies: 3Last Post: 23rd Nov 2007, 05:52
