  1. hey pplz
    i have a 1.35gb xvid file that i would like to convert to svcd over 2 cds the movie created is 3h:16m im having difficulties creating the svcd can nebody point me in the right direction
    thanx for the help
  2. <------------------Guides This Way
    If God had intended us not to masturbate he would've made our arms shorter.
    George Carlin
  3. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    No way you can get an SVCD with 1h:38m per disk (ie 2 disks) that will be worth watching. The bitrate is far too low at 800 kbps.
    Even 3 disks of 1h:5m each is at the far end of the range for SVCD, as the bitrate will be 1400 kbps. If you use TMPGEnc, 352x480 (CVD) resolution and 2-pass VBR (0 min, 2500 max, 1400 avg.) the quality will be acceptable. Look for CVD templates in the Tools section.
    Even better is to put it on 4 disks. CD's are cheap.
    Here's a guide.
  4. thanx for the help fellas
