Hi,
I am trying to reformat computer using the winXP cd. I want all the files on the hard drive deleted also. When I try to use the cd to reformat and delete all the files on that drive going through all the options and steps, I must being picking the wrong options in the winXP profession setup because it loads winxp it looks like a new copy, however, when the hard drive is loaded all the files are still there and the only thing that is pretty much deleted are the desktop icons.
How do I tell the winXP cd to delete all the files on the hard drive also? Please and thank you.
When you first load the CD, the setup program asks which partition you wish to use to install Windows XP.
Choose the partition (C
. Then it tells you NTFS is already installed on this partition - do you want to leave the file system as is or reformat?
Choose reformat - it will completely erase your hard disk
Your mistake is probably choosing to keep the existing file system.
Cheers
eSATA not hotpluggable with WinXP?
By PartingShot in forum ComputerReplies: 6Last Post: 13th Sep 2010, 19:59 -
WinXP SP3 Problems
By bevills1 in forum ComputerReplies: 5Last Post: 1st Aug 2010, 22:48 -
WinXP Thumbnail Change
By Anakha in forum DVD RippingReplies: 1Last Post: 19th Feb 2010, 10:44 -
problems with v2.5 install on winxp
By welthqa in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 27th Aug 2007, 16:37 -
Two problems with WinXP re-install
By tweedledee in forum ComputerReplies: 9Last Post: 23rd Jun 2007, 20:38
