I'm using Ati TV wonder Pro .Capturing analogue TV & VCR is good.When recording the capture and playback, no more sound !!! Any suggestions?
Thanks![]()
Results 1 to 10 of 10
Is it copyrighted material. ATI won't do it. I get blurry playback with copyrighted. For that I'll use the freeware Virutal VCR.
You probably have the wrong audio input selected in the initialization wizard.
Why would copyrighted material record video but not audio?
Check your Mixer Recording selector. -
I've check in the initialization :They said:
Driver : Ati Tv wonder Pro A/V capture (unsupport).
I'm a newbie , I don't know how to do. Do i have to change this Ati adapter with another Ati Radeon ? for exemple :Ati All-in-wonder 9700 Pro
(AGP video card)?
Thanks -
Open ATI-TV. Click on setup (the little checkmark on the bottom). Click on the Display tab. Click initialization Wizard. Keep clicking Next til you reach the audio connection section.
Do you have sound during regular TV shows (without recording)? Check your line-in volume under playback properties. Also, check the record properties and verify the line-in is selected as the source device.
can not record in +vr mode
By bad channel in forum Capturing and VCRReplies: 9Last Post: 11th Jul 2017, 17:00 -
How to record HD TV?
By iRecycle in forum Capturing and VCRReplies: 19Last Post: 28th Nov 2014, 18:46 -
Possible to record HD TV Via Cable
By onesikgypo in forum DVB / IPTVReplies: 10Last Post: 21st Jul 2012, 12:08 -
Trying to record ONLY commercials
By Ch3rryC0ke in forum DVB / IPTVReplies: 7Last Post: 12th Sep 2011, 12:21 -
how to record without pauses
By mehrlicht in forum DVD & Blu-ray RecordersReplies: 2Last Post: 9th Apr 2009, 16:00
