I am trying to convert svcd movies into a dvd-r, but my files that I removed from the mpeg folder are in mpeg extensions and I need to change them to .dat extensions. I am sure it is an easy process, but just right clicking on the file and renaming the file doesnt change the ext. How do I fix this? Thanks
I don't think you are following the correct process for SVCD to DVD conversion. A *.dat is an mpeg1 on a VCD disk, while an mpeg2 on an SVCD has the extension *.mpg. You do not normally need to change the extension in order to convert from SVCD to DVD. Are you following a guide?
I suggest you search the guides under format conversion - SVCD to DVD. You will get quite a list but there are two basic methods:
-One method takes the SVCD video as-is and puts it on a DVD. This method is fast but because SVCD video is not DVD compliant, it creates a DVD that will not be compatible with a wide variety of DVD players.
-The second method will re-encode the video so that it becomes DVD compliant.
Good luck."Art is making something out of nothing and selling it." - Frank Zappa -
I am using this guide:
http://www.dvd-guides.com/guides.php?category=othertodvd&name=tmpegencvcdtodvd
But I have vcd and svcd movies and the svcd has 4 folders in it, but my computer is recognizing this file as a mpeg. -
Originally Posted by teckerd"Art is making something out of nothing and selling it." - Frank Zappa
Perfect, you nailed it. I do have XP and I changed that setting and it allowed me to see and change the ext. Thanks again.
IMGBURN shell ext query
By nawo69 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 22nd Nov 2010, 10:21 -
ext hdd works on philips not on pc
By catdaddio6 in forum ComputerReplies: 7Last Post: 23rd Feb 2009, 12:28 -
Ext. USB HD not visible
By juststarting in forum ComputerReplies: 4Last Post: 12th Jan 2009, 10:59 -
Ext. HardDrive's any recommendations?
By StuR in forum ComputerReplies: 9Last Post: 7th Feb 2008, 07:57 -
playing ext hard drive through tv
By telmealing in forum Newbie / General discussionsReplies: 3Last Post: 10th Oct 2007, 14:13
