hello
i use dvapp or adobe premiere to make my captures.
I want to capture one program that will broadcast when i'm not at home so i'd like to schedule my computer to capture it. anyone can help me doing it with dvapp or premiere?
I'm using this programs cause it's the ones i have. i use a canopus advc-1394 for my captures.
thanks for any help. please reply fast cause i need to do this tomorrow![]()
not sure it's possible, i use DVapp as well but there's no kind of "start recording when opened" option so simple windows scheduling won't work.
do you have enough HD space to just set it going before you leave and edit it? can you leave it all set up for someone else to hit record? can you get to another computer to start it remotely? -
no
no
no
any other suggestions? -
dare i say VHS?
i bought a DVB PVR because of this, could never find a reliable solution....
last thing i know of, check out www.showshifter.com they were introducing DV capability at some point, it may be fully working now - haven't used it for about a year. -
i found that scenalyzer has a timer to program.
i guess i'll use it.
this program is ok to capture?
Capture on FCP, edit on Premiere
By benchaz in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 28th Nov 2008, 11:34 -
HD Capture questions w/ Premiere pro
By miamibluemoon in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 19Last Post: 27th Feb 2008, 02:38 -
Premiere - how do I change capture format?
By djbryson in forum Capturing and VCRReplies: 15Last Post: 17th Nov 2007, 10:42 -
Choppy capture from HI8 in Premiere
By tmann in forum Newbie / General discussionsReplies: 1Last Post: 17th Jun 2007, 15:24 -
SVHS Capture / Premiere Pro 2
By tokyomaskproductions in forum Capturing and VCRReplies: 4Last Post: 16th May 2007, 14:48
