ok i have alot of anime avi files, and i want to burn them, but i would like to cut out the intro and outro in my avi, i need a program that is easy friendly.. i know TMPGEnc can do it, but i dont understand YMPGEnc that good.. dont know how to use the cut tool in TMPGEnc
Use Virtual Dub instead. Load the video, select the Mark in point, press the Mark in button. Select the Mark out point, select Mark out point. Press delete. Save under a new file name.
Hello. -
Virtualdub. Mark the area to cut, press Delete key on keyboard. You can only cut at keyframes if using "Video -> Direct Stream Copy", and AVI files sometimes have as much as 10 seconds betwen keyframes, very bad. Anyway, when finished editing it, click "File -> Save as AVI..." or frameserve it to tmpgenc (File - Start Frame Server..)
Use .MTS files in Final Cut Pro while keeping original dates in the files
By Winterburn in forum MacReplies: 3Last Post: 18th Aug 2011, 16:21 -
Cut AVI Files
By emoreira in forum EditingReplies: 2Last Post: 25th Sep 2010, 10:16 -
How I can cut TS files ?
By Torresinho in forum EditingReplies: 1Last Post: 14th Feb 2010, 15:15 -
Final Cut Pro not playing .avi files captured with CamStudio
By imagine3 in forum MacReplies: 1Last Post: 29th Sep 2009, 11:57 -
swf to avi - last few frames of animation get cut in the avi - any solution
By perfection in forum Newbie / General discussionsReplies: 0Last Post: 5th Sep 2007, 08:01
