hi people,
please some help.
i don't understand it anymore.
i reauthor my own dvdr
i insert subtitles.
demux audio and m2v with vobedit.
put it all together with chapters and my own subs.
i use different software and i can work with them all.
but here is the problem.
i reauthor a dvd (m2v, audio demuxed by vobedit) own subs (from srt 2 sup).
when i play the dvdr normal from the beginning everything is good.
after a while the subs are gone and then shortly after that, the movie makes a shock and then everything is good again.
this happens a few time in the dvdr.
but now it comes, when i only select one vob file with powerdvd then there are no subs and the dvd plays just fine.
why is this happening? i don't understand it.
where is the error then?
PLEASE SOME HELP.
if i select 1 vob in powerdvd it plays fine.
if i play the dvd selecting the complete dvd it sometimes stops with the subtitle and after a minute or 2 the video gets jerky and then everything is good again for a while.
i tryed to demux the video with dvdDecrypter instead of vodedit and reauthor it again.
but on the exact same time codes i get the problem again.
so the way of demux does not matter.
could it be the srt 2 sup converthing that gives the troubles?
i used dvdsupencoder.
strange thing is that i had this trouble before but with dvdmaestro.
i convert srt 2 stl with subtitle workshop.
so this are different ways but with the same troubles.
please people, does anybody recordnice this and can help me?
Thanks. -
Appie,
How did you INSERT the subtitles? Another word, what program did you use to re-author the new movie? -
I used rejig.Originally Posted by Faithful Follower
And the reason is that the audio was dts.
In ifoedit , for some reason the 5.1 channel was damaged.
But that was not the problem.
i have seen the same trouble when i used DVDMaestro and created srt with subtitle wokshop 2 stl.
i used srt2sup this afternoon to create a sup file.
used rejig again and have 2 see if this works.
have you seen this problem before?
And again the same trouble but at different timelines.
I tryed demux m2v with dvddecryter and audio with vobedit.
sub with srt2sup.
author with rejig.
I'm lost and don't see the problem anymore.
Hi
same problem for me, any solution for this?
I can't sleep for 3 nights working and searching but no clue of how to fix it -
Try dvdauthor with either dvdauthorgui or GUI for dvdauthor. These progs accept dts sound and srt subtitles (directly). The subtitles are rendered and muxed into the vob files with spumux. Maybe that helps...
Burnt DVD with vob problem (not playing on computer)
By lamaddvd in forum Newbie / General discussionsReplies: 7Last Post: 17th Feb 2009, 15:28 -
Problem with Audio when playing VOB dvd files
By rbrown871 in forum AudioReplies: 9Last Post: 8th Dec 2008, 10:36 -
Problem expanding subtitle time with Subtitle Workshop
By Kaze105 in forum SubtitleReplies: 1Last Post: 11th Nov 2008, 23:16 -
how to make a DVD subtitle as a default playing subtitle
By yozloy in forum Authoring (DVD)Replies: 3Last Post: 15th Sep 2008, 11:51 -
Problem playing DVD on laptop with subtitle
By V0RT3X in forum Newbie / General discussionsReplies: 4Last Post: 14th May 2007, 16:36
