Hi,
got a quite complicated problem here. I have several SVCDs which I encoded from edited DV material (bottom field first). Now I want to create a new DVD with material from these SVCDs, but first edit it in Premiere to add some effects and stuff. Therefore I converted them (or just one for testing) back to DV (Panasonic codec) with Virtualdub-MPEG2. The DV standard for PAL requires 720x576, so I had to enlarge the source, which was 480x576. Doing this without deinterlacing got me effects like with wrong field order, but much worse. With deinterlacing, the effects are very small, but still there. After encoding the DV avi back to mpeg2 with CCE (for DVD, thus without need to resize again), on TV the effects are still there.
Hope I didn't confuse you too muchI tried swapping fields with a vdub filter, but without getting better results. I guess the field order should be right anyway if i don't change anything during the conversions?
Has anyone an idea how to get this right? There's no other way than converting the SVCD back to DV if i want to edit the video in Adobe Premiere, right? Thanks for your help![]()
resizing from 480x576 to 720x576 shouldn't give an issues, you're just changin horizontal resolution not vertical. check exactly what resize settings you're using in Vdub...
ok thanks, bilinear resizing without deinterlacing in vdub seems to work. just needed to change the field order in cce again
How do you rip content from DVD so it can be edited in iMovie?
By devzin98 in forum MacReplies: 4Last Post: 25th Jul 2008, 11:52 -
Taking edited DV footage to DVD with Premiere Pro
By Orange_Eagle in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 14Last Post: 23rd Mar 2008, 20:33 -
DVD to AVI HELP!! I need an AVI that can be edited in Adobe Premiere.
By nimdivino in forum DVD RippingReplies: 4Last Post: 13th Sep 2007, 19:35 -
Capture DVD to be edited/clean?
By mlong30 in forum Capturing and VCRReplies: 13Last Post: 17th Jun 2007, 23:13 -
Burning edited DV movie to DVD
By roster19 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 21st May 2007, 01:40
