I was looking at "How to make a monster". This movie uses a state machine to figure out what goes on in the menu.
One of the menus is a screen asking if you want the full-screen or the wide-screen version.
To reverse engineer that section IFOedit has the DVD-PLAY function. Which is great. Had it not been for that IFOedit is using M$ DVDPLAY.exe
This player crashes in the menu taking IFOedit down with it. It crashes in many menu's though which really stinks.![]()
Can IFOedit be made to use another player for this function or is it bound to the M$ player?
Do any of you have the same problem as I? I am concerned about this because I know that the m$ player doesn't come with its own mpeg2 decoder but relies on other later installed codecs. So possibly there could be a codec problem on my machine.
Results 1 to 1 of 1
Problem with x264.exe (MeGui)
By yomz in forum Video ConversionReplies: 7Last Post: 28th Sep 2011, 21:23 -
Have a region 0 DVD, but my HP DVDPlay won't play my R1 DVDs
By scc1983 in forum Software PlayingReplies: 2Last Post: 24th May 2010, 05:19 -
FAVC.exe Problem
By SilverDales in forum Video ConversionReplies: 2Last Post: 26th Jan 2008, 17:16 -
explorer.exe / drwtson32.exe keeps closing
By coolcoates in forum ComputerReplies: 7Last Post: 28th Nov 2007, 08:42 -
ffmpeg.exe crashes when loading an asset
By boggle in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 1st Jul 2007, 12:55
