I have a DivX AVI that I downloaded, and when I try to convert it in TMPGenc there is no audio shown in Audio Source. All version, 12a, 12j and 2.01.
When I open it in V-dub and check file info, it says
Compression: Unknown (Tag 2000)
The exact error message I get is;
"File can't be opened or unsupported."
When I try to rip the audio to wav I get the following error message;
"The requested audio compression is not compatuble with the input format. Check that the sampling rate and channel count of the input match those of the requested format."
When I click ok it says;
"AVIOutputWav: The handle is invalid."
But when I rip with using direct stream copy it works.
Why??
The file information is;
Sampling rate: 48000KHz
Channels: 2(Stereo)
Sampling precision: 0-bit
Compression: Unknown (tag 2000)
Preload skew: 1200 samples (0.25s)
# of frames 107627
Min/av/max/total frame size: 11/1101/12000 )105219K)
What can I do to fix this??
<font size=-1>[ This Message was edited by: AnnihilatorTokyo on 2001-11-12 06:26:33 ]</font>
<font size=-1>[ This Message was edited by: AnnihilatorTokyo on 2001-11-12 06:27:03 ]</font>
I believe you're in my same situation, it may be that the DiVx audio codec is the "Morgan stream switcher", which supports multilanguage. I don't know any converting tools who supports it. Does anybody know?
mp4tools/mencoder - compressed with an unknown/unsupported compression
By furrytoes in forum MacReplies: 4Last Post: 3rd Sep 2011, 09:48 -
Adding 3d tag?
By catdaddio6 in forum Newbie / General discussionsReplies: 7Last Post: 10th Aug 2011, 19:47 -
problem with compression using virtual dub
By jpez1 in forum Video ConversionReplies: 4Last Post: 3rd Aug 2010, 14:24 -
no options in audio compression for virtual dub
By jonbaker in forum AudioReplies: 9Last Post: 14th Feb 2010, 20:00 -
Unknown Disc on Tevion Model no TCHT 2000
By Brimac in forum Newbie / General discussionsReplies: 5Last Post: 1st Jan 2008, 12:39
