I'm trying to copy a homemade DVD. When I try and copy the DVD, I'm using Nero or Record Now Max. I get the message saying that there is not enough room on the target disc to make a copy. Yes I'm using a blank disc. If I copy the files to my harddrive, I get a read error. Would this be due to some sort of copy protection on the DVD. If it is, what is the best way around it. Thanks.
Two words for you:
DVDDecrypter
DVDShrink
It's not as simple as just dragging the file off the DVD onto your hard drive. Read the guides and use these tools. Trust me, you'll be glad you did."It's getting to the point now when I'm with you, I no longer want to have something stuck in my eye..." -
Correct me if I am wrong, DVD Shrink has already embedded DVD Decrypter.Originally Posted by NilfennasionSam Ontario
yeah,
But I still use DVDDecrypter to rip, guarantees working backups
Sounds like you're running out of space as the source DVD may be a DVD-9, you need to transcode that DVD to fit a DVD-R (DVD-5)
For free software use :
DVDDecrypter
DVDShrink
AutoShrink ISO
Apparently DVDShrink 3.1.7 beta 5 now included the ability to rip protected DVD's, so you may not need DVDDEcrypter anymore......
But I always rip with DVDDEcrypter as it works everytime for me, you'll find your own method eventually ! -
The DVD is a DVD-5. I tried DVD Decrypter and got the folllowing error "CIRC Unrecovered Error"
Make sure you clean the disc. If worse comes to worse you could try creating an image using Alcohol 120%, as it's able to skip read errors. Your picture might end up being distorted in parts but at least you can copy it.
Weird problem with homemade DVD
By euroboy in forum Authoring (DVD)Replies: 12Last Post: 31st May 2011, 19:49 -
Can't play homemade DVD copies on player
By poz3614 in forum Newbie / General discussionsReplies: 3Last Post: 18th Nov 2010, 07:26 -
No audio from homemade DVD
By lloydswylie in forum Newbie / General discussionsReplies: 4Last Post: 30th Mar 2010, 15:00 -
Video aspect on homemade DVD
By KayAt in forum Newbie / General discussionsReplies: 1Last Post: 6th Dec 2007, 16:04 -
Problem Copying Homemade DVD
By Anonymous642 in forum Newbie / General discussionsReplies: 8Last Post: 28th May 2007, 14:04
