I've got a couple of programes on my Tivo that I'd like to put on SVCD. I've been using DVD2SVCD for a few months now, so I'm a bit familiar with some of the programs, but DVD2SVCD just makes it so darn simple (complement to author).
Has anyone used a DV500 capture board and adobe premeier 6.0 to grab something from the S-video IN and take it through the process to CD? (SVCD) If you have, could you share your method. I'm interested in the following:
1. How did you set up Premeire to capture?
2. What did you do with the resulting file
3. What programes did you use?
4. Any special settings or tricks to make this easier?
Roveer
Results 1 to 1 of 1
What program can I buy so i can make a vid like gopro hero2 vid
By DROCK71 in forum Newbie / General discussionsReplies: 5Last Post: 21st Mar 2012, 13:01 -
[Closed] Vid capture problem- aud/vid synch issues...?(Dazzle VidCreat+HD)
By Diana (Cda) in forum Capturing and VCRReplies: 2Last Post: 22nd Dec 2011, 10:50 -
Pinnacle Dazzle to watch a camera in real time and to grab frames
By quartet401 in forum Newbie / General discussionsReplies: 0Last Post: 29th Jun 2009, 17:03 -
Pinnacle DV500 Plus crashes on installation
By Dr.Rock in forum Capturing and VCRReplies: 2Last Post: 12th Feb 2009, 12:27 -
Vid encodes will only display first frame instead of loop at the end of vid
By SignedupGuest in forum Newbie / General discussionsReplies: 6Last Post: 8th Aug 2008, 22:09
