I have sifted through the source file in order to make a DVD from some old VCDs, and everything is fine until I get to the output stage. Then I get this message:What gives?Read Error Occured at address 00516e68 of module 'TMPGEndDVDAuthor.exe' with 00000140![]()
Results 1 to 12 of 12
"It's getting to the point now when I'm with you, I no longer want to have something stuck in my eye..."
You could try downloading a newer/updated release and try again.
PS: Does the VCD have 48khz Audio or 44.1 ?Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
According to the screen I get when I try to add the files to the project, it actually has 224 kbit MPEG 2.0 audio. I kid you not (I got these VCDs kind of third-hand).
"It's getting to the point now when I'm with you, I no longer want to have something stuck in my eye..." -
Every VCD has 224kbps MPEG 2.0 (Stereo) audio files
But that doesn't say it it's 44.1 khz (Standard VCD) or 48khz (VCD to be burned on DVD media).Email me for faster replies!
Best Regards,
Sefy Levy,
You shouldn't have to process the video at all. I'm a little unclear on why you are doing so.
I have just figured out that the audio component of these files is 44.1Khz. So now the question is merely how I convert them.
TMPGEnc DVD Author can do the resampling for you. Or you can demux the mpegs and use FFMPEGgui to resample into a new mp2, then you'll have to mux the new mp2 with the mpeg. TMPGEnc's MPEG Tools can do the muxing/demuxing for you.
You mean TDA? All you have to do is add your mpeg and it will be resampled in the output stage.
I found an option to set the output track as Linear PCM with 48Khz audio. It seems to have solved the problem, although I suspect the end product will sound like cack.
Well, I've burned the disc, and it seems to work just fine on the SD-1300. So thanks for all the help. I'm so glad someone pointed me to this site. I feel like I can accomplish anything video now.
TMPGENC 4.0 Xpress Weird Problem! (Shows Green Bar On Left Side Of Video)
By hypnoticpimp in forum Video ConversionReplies: 16Last Post: 11th Jan 2010, 07:36 -
By hypnoticpimp in forum Newbie / General discussionsReplies: 2Last Post: 15th Apr 2009, 02:17 -
By hypnoticpimp in forum Authoring (DVD)Replies: 1Last Post: 14th Apr 2009, 09:05 -
TMPGEnc DVD Author 1.5 Problem... Only with these files... Weird, Help!
By acid_burn in forum Authoring (DVD)Replies: 3Last Post: 11th Jun 2008, 12:50 -
xvid files act weird in TMPGENC
By briansmccabe in forum Video ConversionReplies: 4Last Post: 11th May 2007, 22:53
