i followed the tutorial on the site to backup a original dvd ,using dvddecrypter ,dvd2one and copytoDVD but when i start up dvd2one i get a screen.where i can choosse the language ,font size ,and splash screen.
does anybody know what to choosse here ,thx.
Results 1 to 11 of 11
Hello, I just set it for settings screen and it skips to that screen on each startup.
PS: I use DVDDecrypter-->DVD2One-->Nero myself...works great! -
The best and most reliable way to burn a DVD IMHO is to use ImgTools classice version along with DVD Decrypter.
DVD2ONE will give you a VIDEO_TS output of DVD files (IFO, VOB, etc.)
Make sure you put these in a folder on your HDD called VIDEO_TS and put the VIDEO_TS folder inside a folder that has the name of your DVD.
So if you want to call your DVD "MYVIDEO" then you have a folder called MYVIDEO and inside that folder you have a folder called VIDEO_TS that has your DVD2ONE output.
Now fire up ImgTools classic version and select NOT the VIDEO_TS folder but the MYVIDEO folder.
It will create a single large ISO IMAGE file for you. This only takes a couple of mintues or so.
You can then use DVD Decrypter to burn that ISO IMAGE file to a DVD recordable disc.
In fact you can set up ImgTools (remember to use the classic version) to auto start DVD Decrypter and begin burning all automatically ... just be sure to pre-load a DVD disc.
This is probably the most safe way to burn a DVD
Please note that your ISO IMAGE file could go over 4GB in size so you need to have the NTFS file system (WinXP or Windows 2000 etc.) as older version of Windows (such as 98 or ME) use a different file system that cannot make files over 4GB
The process I told you about is using 100% freeware programs.Originally Posted by nokiatune2001
Also it is considered by many to be THE best method of burning a DVD eventhough it is using all freeware programs.
Many people (myself included) consider Easy DVD Creater a POS (Piece Of Shit).
Thus the reason why I explained another alternative that is not only the BEST but also FREE. Rarely does that combination happen!
Stay away from Easy Coaster Creator as fulcilives said. You may want to review the Tools section and check the reviews on the various ripping, burning and transcoding programs...
the best way ive found to back up an original dvd is clone dvd,you got to have any dvd installed as well.just put your original in the dvd reader,put your blank dvd in the writer,set clone dvd going,and within the hour you will have a perfect backup,full menus ect.
hope this helps. -
I don't think CloneDVD decrypts the disk though so you still need a ripping or decrypting tool.Originally Posted by ggartside2
try Dvddecrypter, dvd2one, copytodvd
What We Do In Life, Echoes In Eternity....
How to PROPERLY burn DVD2ONE DVD's using TOAST 6.0
By galactica in forum MacReplies: 170Last Post: 30th Mar 2012, 03:48 -
DVD2One: Unable to create vobfileset 0...
By Ryan Kelly in forum MacReplies: 3Last Post: 27th Nov 2009, 11:00 -
Weird DVD2one conversion-7 GB compressed to 2.6 GB on diskcopy, why??
By ruggerjvd in forum MacReplies: 2Last Post: 2nd Jan 2008, 11:26 -
Question about seamless joining in DVD2One
By jwnulife in forum MacReplies: 12Last Post: 20th Dec 2007, 07:03 -
Program like DVD2ONE?
By Soccerman77 in forum Newbie / General discussionsReplies: 7Last Post: 26th Nov 2007, 17:11
