In backing up my Simpsons sets, I dispensed with the menus anid a movie only copy in DVD2One, leaving me with one long clip with all the episodes.
I dropped the episodes into Toast to make a menu to direct to individual episodes, but I lost my commentaries. It seems that I can only have ONE audio track with Toast.
Is there a way to remedy this?
Quick question.
Why get rid of the menus just to create new ones? -
Quick answer:Originally Posted by tgpo
Mind altering substances.If it isn't broken, take it apart and find out why.
blog: deadsierra -
I was fitting 2 discs onto 1 DVD by joining the episodes together and then shrinking the whole thing down to size.
Toast only supports 1 audio track in Video format. If you want to keep both tracks, you will need to have a Video_TS folder and burn the DVD in DVD-ROM format. You could just use the Join feature in DVD2One and then burn the resulting Video_TS folder.
How to choose audio track in avi file with two audio tracks
By newnews in forum AudioReplies: 3Last Post: 26th Oct 2010, 06:26 -
Video with L/R tracks to DVD with 2 channel audio tracks
By Downloader in forum Authoring (DVD)Replies: 2Last Post: 22nd Aug 2010, 02:56 -
DVD to MPEG2, extract mult audio tracks, subtitles for replay in WD TV Live
By Jacoman in forum DVD RippingReplies: 5Last Post: 16th Mar 2010, 10:40 -
No Audio On AVCHD-DVD, How To Remove Other Audio Tracks From MKV File First
By elistian in forum Video ConversionReplies: 1Last Post: 14th Dec 2009, 07:03 -
Best Practices for Archiving DVDs -- Keeping Mult. Audio Tracks, Subtitles
By GrayStrickland in forum DVD RippingReplies: 5Last Post: 27th Jan 2009, 11:27
