I use Intervideo winproducer3 to create my vcds and never had a problem, now i was trying to create svcd so I imported my captured avi 640x480 , edited it, rendered and burned to cd as svcd pal video. When playing cd in my Daewoo DVD the whole movie jerks and parts of screen disappears it is a total mess I could not watch even 10 seconds of these cds, I tried to burn the same project to another type of cds but still the same i changed my render into secam and no use, I wonder what I am doing wrong because the cds play excellent on my pc cd drive , why ??
Thanks for any help.
Might be too high bit rate? Even if a player supports SVCD, many has trouble with bit rates above 2000 kbps total. Try lowering it (which may mean using a stand alone encoder and not some all-in-one deal like winproducer).
/Mats -
i noticed that i can not adjust bitrate from anywhere in winproducer and settings are so limited so what alternative do i have ?
thank you -
You should encode NTSC SVCD with 480x480 resolution so you need to resize 640x480 to 480x480 if you have not done it already. It may also be a field order problem if you are encoding interlaced video. You can change the field order flag with ReStream or reencode with correct field order (can be either upper field first or lower field first depending on your capture hardware).
Ronny -
TMPGEnc to encode, VCDEasy to author & burn. That gives you 100% control of your process.what alternative do i have ?
/Mats
Random Video Jerks on Input Source to Viewcast Osprey 240e
By nephesh in forum Video Streaming DownloadingReplies: 1Last Post: 24th Feb 2011, 10:14 -
how do I know if an avi can be played on a dvd
By flannob in forum Newbie / General discussionsReplies: 4Last Post: 9th Aug 2010, 13:33 -
UK DVD's played in US
By jack209 in forum Newbie / General discussionsReplies: 11Last Post: 24th Oct 2009, 17:34 -
Can a SVCD video file be burned on to a DVD and played in a DVD player?
By dvdnewbie64 in forum Newbie / General discussionsReplies: 9Last Post: 17th Apr 2008, 21:44 -
Dvd jumps when played
By Radox The Green in forum Newbie / General discussionsReplies: 1Last Post: 16th Dec 2007, 14:56
