  1. I'm trying to use QuEnc to encode dv2 avi files. No matter what I do, it can't seem to read my AviScript file to start the encoding. I know that he last line needs to be ConvertToYV12() but it doesn't seem to get that far. I've tried frameserving files from VirtualDub and just using single avi files not frameserved. I've tried starting the first line with AviSource and DirectShowSource, Media Player Classic will read The script files that start with DirectShowSource. It's probably something simple I'm missing as I have been able to frameserve to other encoders with VirtualDub, but now I am determined to figure this out. Any suggestions would be appreciated.
    Nyah Levi
    Aug 2002
    To use AviSource you need a codec for your avi file. I guess DV 2 is DV type 2 avi? You can use Canopus DV codec or mainconcept DV codec with avisynth. But directshowsource should work even if you don't have a DV codec.
    Can you post your avisynth script?
    Ronny
  3. Post your script.
  4. Yup, post your script.
    QuEnc cant open virtualdub frameserver posts, you need to do it via AviSynth with a script like this:
    AviSource("c:\VirtualdubFrameserver.vdr")
    ConvertToYV12()
