I got a MiniDV cam and it has analog inputs (and supports passthru) so to transfer my stock of VHS-C tapes I figured this is the best approach.
Problem is, I'm not sure how to set the Field order. Since I need to do some decent ammount of editing, I will be capturing in AVI, then after editing convert to MPEG2.
I have Ulead VS 7 SE. I'm contemplating about VS 8. But here's my confusion on field order.
From what I found, for DV material, I should set VS7 to Field Order A. VS8 would be Lower Field. Interestingly enough, tmpgenc calls this Bottom Field First (Field B).
Analog capture (via TV Capture card) would be the opposite. That is, for VS7 Field Order B, VS8 Upper Field (and tmpgenc Top Field First (Field A)).
But, when you do passthru, which one should I set it to ? DV capture settings or Analog capture settings ?
TIA...
Ive found that it doesnt matter what you set the capture up for in mediastudio. I had it set up to capture top field, bottom field and it always captures in bottom field. Dont let this issue worry you, just go and capture it. It should capture bottom field.
Field Order
By Tafflad in forum Authoring (DVD)Replies: 9Last Post: 30th Jan 2010, 00:38 -
field order and cce
By cd090580 in forum Newbie / General discussionsReplies: 3Last Post: 17th May 2008, 16:11 -
Field Order Problem?
By GordRocks in forum Authoring (DVD)Replies: 3Last Post: 4th Mar 2008, 09:19 -
Determining field order
By dadrab in forum Video ConversionReplies: 2Last Post: 4th Oct 2007, 15:09 -
Field order?
By miamicanes in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 12th Sep 2007, 16:14
