I am using DVD Shrink 3.1 and when I burn movies, it says compression is around 56%. I am not sure what that means. I am guessing the lower the number (closer to 0%), the better the quality?
I noticed that the burned dvdr quality isnt AS GOOD as the original? How can you make it close to the same quality of the original?
Hi,
You have crossposted.
Please read the rules and AUP before posting if you have
not already done so. They can be viewed by clicking [HERE]
Thanks,
Mod Offline
Lose the extras and menus.
"Art is making something out of nothing and selling it." - Frank Zappa -
dont cross post:Best way to burn quality dvd-r's?
https://www.videohelp.com/forum/viewtopic.php?t=224090 -
Errrrrhhh WRONG !I am guessing the lower the number (closer to 0%), the better the quality?
Lower the % number the worse it will look. (compared to original)
100% is same as original - 50% is half the "quality".
As stated, either REMOVE the unnecessary video/audio or SPAN it across 2 disks. Simple.
Do a little homework and search previous posts... The question is so general that it shows you really haven't looked. There is an enormous amount of previously posted info at you fingertips if you just search first.
How to burn 1920x1080 mpg to dvd without loss of quality?
By ABUELLO in forum Authoring (DVD)Replies: 31Last Post: 1st Apr 2013, 15:48 -
Samsung SH-S243D DVD writer - CD media burn quality
By onland in forum DVD & Blu-ray WritersReplies: 9Last Post: 6th Feb 2012, 23:52 -
Double layer DVD-can I burn 2hr at Highest quality?
By jbitakis in forum Authoring (DVD)Replies: 2Last Post: 21st Apr 2011, 12:59 -
Movie quality is bad after burn to DVD
By ngochan in forum Video ConversionReplies: 4Last Post: 26th Jan 2011, 00:34 -
Does SVCD2DVD process and burn HD quality DVD from HD .ts file?
By jeemak in forum Authoring (VCD/SVCD)Replies: 1Last Post: 21st Nov 2008, 23:03
