How can i have my computer shutdown after about 2 hours. Can i make a command and have it executed after about 2 hrs.
I would like to have my PC record for about 2 hours then shutdown and force close close any open program; i am interested in using tools available in Windows
Not sure but I think this is only for XP. Right click on you desktop and select properties. Select the screensaver tab then select power at the bottom. Select the hibernate tab and check the enable hibernation box. Now select the power schemes tab and at the bottom will be a selection for hibernation. Never used it so I don't know how well it works.
Just download Chrono Shutdown if you're using xp, it's really easy to use.
http://john.obyrne.free.fr/index.php3?page=chronoshutdown -
you can use the Scheduled Task utility thats already in windows.
here's a link that gives a good direction on how to schedule your computer to shutdown
http://lists.isb.sdnpk.org/pipermail/comp-list/2003-April/002043.html
hope that helps
Is there a way to do a timed recording for the hauppage hdpvr 1212?
By yoda313 in forum Capturing and VCRReplies: 4Last Post: 13th Mar 2011, 18:48 -
Is there a timed channel changer for the comcast dta boxes?
By yoda313 in forum Newbie / General discussionsReplies: 2Last Post: 7th Jan 2011, 20:52 -
AMD X2 4200 Shutdowns
By kenmo in forum ComputerReplies: 16Last Post: 25th Mar 2009, 08:43 -
Accurian ADR 3223-programmed event gets timed out
By critter2king in forum Newbie / General discussionsReplies: 1Last Post: 19th Dec 2007, 13:01 -
Timed USB Mpeg4 Grabber recording. Is this possible?
By GLOpro in forum Capturing and VCRReplies: 2Last Post: 5th Jul 2007, 18:21
