Is there a way to grab the music from movies or grap the music + sfx from dvds?
like taking one of the 5.1 channels and then extract the music/sfx part
is there a way to do this?
like from Star Wars, Harry Potter, you name it dvd?
wouldnt distribute it or anything just for my personall use
Hi,
You have crossposted.
Please read the rules and AUP before posting if you have
not already done so. They can be viewed by clicking [HERE]
Thanks,
Mod Offline
Sure. Rip it, load the VOB with the particular sounds you want into Virtual Dub, edit out what you do not want. Save as a wave.
Hello. -
if you're trying to just get the soundtrack with none of the sound effects you won't be able to do it. You will end up with stray vocals, echoes of things going on in the center channel and various other anomalies. You can extract just from the FL and FR channel but you can't seperate the original tracks that were mixed down within that channel...well, not without the original master...and good luck getting your hands on that!
The Complete Guide To Making Blu-Ray Backups (1:1 Backups + BD5 Backups)
By milOtis in forum User guidesReplies: 225Last Post: 21st Jul 2024, 04:35 -
Does Anybody Need a Soundtrack or Score?
By TheIcarusDescent in forum AudioReplies: 59Last Post: 21st Jun 2011, 01:05 -
How can i change soundtrack ?
By forcedv in forum Newbie / General discussionsReplies: 2Last Post: 20th Apr 2009, 09:48 -
Soundtrack problem
By Den-2 in forum Video ConversionReplies: 2Last Post: 23rd Mar 2008, 09:42 -
EAC3 soundtrack
By shun in forum AudioReplies: 0Last Post: 23rd Feb 2008, 07:35
