My uncle has a Tivo, 6 channel audio receiver, dvd recorder, & a vhs/dvd player. But he cant get them all to work together.
But the Tivo only has 2 slots in the back for other 3 components. I suggested he not hook up up the dvd portion of the vhs/dvd combo and just use the dvd recorder to watch movies but he wants all of the components to work together.
The only other thing I can think of to do is buy like a splicer that will enable 2 input wires, red/white/yellow cord; I dont know what theyre called, for 1 of the 2 slots on the back of his Tivo receiver enabling him to have a total of 3 hookups in the back of his Tivo.
And since the Tivo has the option of having the downloaded program record to VCR, it says as one of the choices on Tivo for downloaded programs "Record to VCR". So if he were to get all of the components working together would it be possible to record programs on his dvd recorder instead of his Vhs or even have the option of using either using that choice.
Hope I made sense with my limited knowledge.
Thanks for your time.
Does the VHS/DVD player combo record? If not then it doesn't need to be hooked to the Tivo to watch tapes/discs on right? Just the TV and sound system. If it does record, I'd still not bother hooking it to the Tivo because it's a waste of time. He's got a DVD recorder, use that!
The "Record to VCR" option doesn't really do anything special. It just plays the recording with a little delay at the beginning telling the name of the show. You can use any recording device hooked to the outputs, doesn't have to be a VCR. Just run the Tivo out signal through the DVD recorder and you're good to record anything you want. -
Yes the VCR does record. And thats what Ive been telling him but hes kinda old & inflexible and wants it done his way.
Yeah, I have an 80 year old grandmother and teaching her to use her DirecTV dish was something I don't wish on anyone. Does he actually plan on using the DVD recorder and giving up on mono VHS? I mean if he's never going to record a tape, just tell him you hooked it up and he'll never know.
Seriously though, you can use cheap RCA splitters to solve this problem. They cost about $3-$5 each at places like best buy and are easy to use and do exactly what you want.
Here's a link to a page with pictures for you. These just plug right in and turn one RCA output plug into 2. These can be used for video too, but the coloring can get confusing because they don't make yellow, just red and black.
http://www.abccables.com/255-038.html
Do I have the right slots for the Avertv HD DVR?
By MichaelEatsWaffles in forum Capturing and VCRReplies: 2Last Post: 11th May 2010, 23:42 -
PCI E Slots question.
By A Traveller in forum ComputerReplies: 13Last Post: 9th Oct 2009, 12:05 -
PCI slots are starting to act up due to one faulty AGP video card ?
By MidnightMike in forum ComputerReplies: 9Last Post: 8th Nov 2008, 17:05 -
DVD encoding issuses w/ progressive fames plays back as interlaced. SOLVED!
By ty1er in forum DVD RippingReplies: 1Last Post: 19th Aug 2008, 09:34 -
Hi havent done much dvd burning in awhile and had quick question
By pitten247 in forum Newbie / General discussionsReplies: 5Last Post: 15th Jan 2008, 21:10
