Hi everyone,
I just got this Philips DVP642 and experiencing this problem before and after firmware upgrade (04/09). I put in a divx/xvid disc and it would play the movie out in PanScan mode even when I change the mode to letter box or 16:9 through the System menu. I put in a real dvd movie that has the format of 16:9 and it plays it as 16:9 but I can't change to other modes (ie panscan).
The menu option's on DVD player,16:9 or 4:3,refer to the type of TV they play on not the DVD disk. The DVD disk will play the way it's ifo file tells it to play,you cannot change that. I have a DVP642 and all the DIVX file I've played have played the they were encoded. 4:3 or 16:9 play in correct ratio. I have my player set as 4:3PS because I'm using a 4:3 TV.
Then that is very weird, because I have a divx file of my backed up movie that if I play it on my computer, it would be in 16:9. But if I put it in the DVP642, it would do the panscan mode or zoomed in on my 4:3 TV not 16:9 (ie with 2 black bars on top and bottom).
Problem could be the frame size the DIVX was encoded at. 640x352 would be correct for a 16:9 movie. Are you sure the DIVX was encoded at a true 16:9 ratio.
I believe my divx frame rate is: 720X416
But from your thinking, there is no way that the problem I'm experiencing is from the player but the divx file?
Thanks for helping. -
Another post in here (in the long DVP642 thread) said that any file that's 720xsomething automatically gets stretched to fill up the screen. Seems to be a bug in the player.Originally Posted by snesromz99
As of right now, there is no cure for this right?
Anyone know when the next firmware upgrade going to be? Thanks
Aspect Ratio Problem
By maccool111 in forum Video ConversionReplies: 6Last Post: 29th Mar 2010, 08:58 -
Aspect ratio problem
By nlaak in forum DVD RippingReplies: 6Last Post: 4th May 2009, 17:13 -
By Renegade in forum Video ConversionReplies: 8Last Post: 2nd Mar 2009, 21:04 -
By kewowski in forum MacReplies: 0Last Post: 2nd Feb 2008, 09:38 -
By Derin in forum Authoring (DVD)Replies: 4Last Post: 16th Aug 2007, 23:00
