Results 1 to 11 of 11
  1. for quality and size?
    if we compress 2 files to the same size, but the one is wmv the other mpg, which will be better
  2. Assuming you know what you are doing, wmv should always give better quality/file size ratio. Especially Windows Media 9.
    However, MPEG1 files are playable on virtually any platform without any additional codecs needed.
    Also, bad conversion skills can make even the best format look like crap.
    If you don't care much about platform/OS compatibility, use wmv. If you want the files to be most compatible, use MPG.
    Dec 2002
    WMV9 uses MPEG4 codecs, whereas by MPG you mean MPEG2.
    Working from a pure source, then WMV would be about 1/2 the size of a similiar MPEG2. This is using real-world settings, not what M$ says is "DVD-Quality". On non-action movies, you can compress a lot more (joys of variable framerate).
    To Be, Or, Not To Be, That, Is The Gazorgan Plan
  4. Umm, WMV9 does not use MPEG4 and MPG can mean both MPEG1 and 2, but usually, most MPG files are MPEG1.
  5. Member teegee420's Avatar
    Dec 2003
    Southern California
    Umm, you don't know what you're talking about.
    Apr 2004
    The bottom of the planet
    Universal compatibility = better format.
    "It's getting to the point now when I'm with you, I no longer want to have something stuck in my eye..."
  7. Originally Posted by teegee420
    Can you show me any links to where it says that WMV9 = MPEG4??
  8. Originally Posted by SeeingMole
    Hard to say according to this: http://www.afterdawn.com/glossary/terms/wmv.cfm
    The term "proprietary" would probably apply....
  9. I believe this link should pretty much clear it.
    http://www.microsoft.com/windows/windowsmedia/WM7/mpeg4.aspx
    You can download a whitepaper .doc file which if you read it carefully, says that WMV and MPEG4 is different formats and that WMV is superior to MPEG4.
    M$'s propaganda to push it's own proprietary format instead of MPEG4.
