I'm trying to find a program to back up movies using CCE because I love the quality, DoItFast4U freezes demux with Decryptor and DVDRebuild is stating that there's an incorrect framesize 1048/58(???). I have the newest verisons of both, does anyone know what I'm doing wrong on either?
I had that framesize problem too - are u using mpeg2dec3dg.dll or dgdecode.dll ? I had that dgdecode.dll installed i/o the mpeg2dec3dg.dll because the link on the guides page points u to that new version. But I got the mpeg2dec3dg.dll file and put that in my plugin directory and pointed rebuilder to it and that solved that problem.Originally Posted by guns1inger
I am using mpeg2dec3dg.dll (the version for Avisynth 2.5). I have tried it in both the Avisynth plugins folder, and the rebuilder folder (I have found guides that recommend both) and neither makes a difference.
I have checked the ecl files, and they all have the correct frame size, so it is something between rebuilder amd Avisynth.
New PC Burns With Errors
By NOIC in forum DVD RippingReplies: 22Last Post: 29th May 2009, 12:12 -
svcd preview errors & vob file errors
By kiwi76 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 10th Nov 2008, 16:02 -
Disc C2 Errors
By kidcash in forum MediaReplies: 1Last Post: 5th Jul 2008, 11:56 -
check a DVD for errors/read errors?
By ebob in forum Authoring (DVD)Replies: 4Last Post: 5th Jun 2007, 10:53 -
Errors on startup
By johnbrigden in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 23rd May 2007, 05:14
