I have vob files which I rename to mpg, then retrieve in Virtualdub-Mpeg.
then convert to AVI.
When the camera or the subjects within the video move (especially up and down), I get a lot of horizontal lines and/or jagged edges of the subjects as they move.
This is true in the Virtualdub preview panes.
If the source is a film movie you should use IVTC. In the video menu select "frame rate" and then reconstruct fields-adaptive. This will restore the original 23.976 frame rate and de-interlace as well.
Yes, the distortion looks like interlacing, most notable on subject edges.
Inverse telecine set to Reconstruct from fields - adaptive.
With this, the source rate adjustment is set to:
No change (current: 29.970 fps)
I have it set to Full Processing Mode (whatever that means)
Uncompressed.
Still getting interlacing on subject motion.
Must be missing something. -
That's odd. Try again using the de-interlace filter instead of IVTC. Go to Video>Filters>Add>Deinterlace and just click ok, then ok again and save.
Much Much Much Better. Thank-you!
The files are of course huge.
1) Is there some form of compression I can use that won't compromise the quality?
My goal is to rip VOBs from my Phillips-recorded AC3 DVDs, convert to AVI so I can edit in Ulead Videostudio 8 (or similar) (on-screen transitions, titles, etc.), then encode to mpg for authoring back to DVD.
2) do you foresee any problems with this plan and/or other Virtualdub settings I might want to use given the goal? -
Here's the thing, if you plan on converting back to DVD you will need to leave the movie interlaced. De-interlacing is fine only if you plan on viewing your files on your PC. Your PC's display is progressive, which makes interlacing clearly evident.
For compression you should use something that is lossless like Picvideo MJPEG. File size should be around 10gb per hour. There are other compression schemes you can use that can make smaller file sizes, but at the cost of picture quality. You will really notice a significant loss when you export your project from Videostudio if you use a lossy compression.
To use compression in Virtualdub MPEG2, go to the video menu and select "compression", and select your desired compressor. If you decide to use Picvideo, select it and click the configure button. Use a quality setting of 19.
Which Program Produces Better MPEG-4 AVC Quality Videos
By mohawkcr in forum Video ConversionReplies: 0Last Post: 1st Jul 2010, 15:10 -
FLV to MPEG conversion results in no files being produced
By mendojazzhead in forum ffmpegX general discussionReplies: 5Last Post: 16th Feb 2010, 13:23 -
Which format produces better quality overall MPEG-2, MPEG-4 or .x264?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 8Last Post: 31st Aug 2009, 04:00 -
new Virtualdub MPEG - still a colorspace problem with MPEG-&
By sanlyn in forum EditingReplies: 6Last Post: 10th Aug 2009, 23:18 -
How to I get best results when playing MPEG-2 files fullscreen?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 6Last Post: 31st May 2009, 22:31
