According to manual you can do instant timer recording only using front panel (the 30min. increment timer). Is that correct?
I use it a lot (to avoid going through the timer menu hassle). So hopefully it can do this so it would be a good VCR replacement (my multi-system Aiwa is about to break down).
If you just hit the record button a few times, it'll go in (I think) 30 min increments, just like a VCR. It's in use (as usual), so cannot test for you.
Thanks. According to the manual you cannot (unless it's a Japanese translation error). Also checked other non-English manuals and all say you can't:
NOTES:
- You can only perform ITR using the 7 button on the unit’s
front panel.
LG Rh399 Timer Recording from AV Input
By Bashar in forum DVD & Blu-ray RecordersReplies: 5Last Post: 18th Jul 2013, 02:08 -
Remote control WITH timer
By rdbierma in forum Newbie / General discussionsReplies: 0Last Post: 9th Mar 2010, 16:54 -
Pioneer DVR 520H Timer Recording problem....
By Gypsy898 in forum DVD & Blu-ray RecordersReplies: 0Last Post: 8th Mar 2010, 10:42 -
LG DVB-T HDD/DVD Recorder Model RH2T80 - Timer Recording Problem
By KillrByte in forum DVD & Blu-ray RecordersReplies: 10Last Post: 30th Apr 2009, 22:20 -
LiteOn LVW-5005 timer recording fails?
By bevills1 in forum DVD & Blu-ray RecordersReplies: 15Last Post: 13th Jun 2008, 10:37
