Hi There..My American relatives sent a Home Video which I can play in my VCR as this is NTSC compatable.
I recently bought a DVD writer and wanted to record NTSC video on DVD.
Know the basics of Video Capturing..but how would I transfer the NTSC videotape to DVD PAL?
Thank You for your help
It's going to be difficult.............
NTSC/PAL VHS question
Unless you have specific hardware, you're better off getting the relatives to capture it for you.Regards,
Rob -
You don't need to , your UK DVD player will handle NTSC perfectly well.
If you can capture the tape to your HD , just create a NTSC with your file. -
???Originally Posted by andyp1
Yes, UK DVD players can handle NTSC perfectly well, but the problem is with capturing a NTSC source from a PAL spec video recorder/player. They end up pumping out a hybrid PAL60 format which whilst watchable on TV, is very difficult to capture.
The thread I posted will explain.Regards,
Rob -
Thank you all for answering so quickly..so andyp1, I capture the Video in NTSC? And then I presume convert it to PAL or just burn it in NTSC?
My Home DVD player is Multi Region and TV is All formats if that helps?
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 12:33 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 13:57 -
NTSC -> PAL same movie length?
By busta3396 in forum MacReplies: 5Last Post: 6th Mar 2010, 07:30 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 22:43 -
Is “Movie Clone 4 Gold” capable of converting PAL into NTSC?
By coody in forum DVD RippingReplies: 3Last Post: 5th Dec 2007, 17:39
