  1. i have a problem with record now under winXP,it doesnt work
    for me.... Has any1 had the same problem and what should i do???????
  2. also discjuggler doesnt work do they have a new build yet, for winXP of course????
  3. Actually DiscJuggler does work, I've been using it for a few weeks now, I do not use RecordNow, but you do need a file in the EZ CD Disk the burner came with called ASPIINSTALL.EXE or something like that to burn with your regular programs, but after the installation, everything works like it did on my old WinMe system.
    I dont use EZ CD though, since I prefer Nero.
