I have edited what i want in my video but when the person recorded through his videocam he left the " time and date " icon on so everything he taped in the movie shows the time and date at the bottom and i dont wont that.... is there a way in vegas 5 i can edit that out and if not what software do i have to use ?????
you can only crop it out in vegas -- but you can use the logo away filter in virtualdub
If it was DV, and you can transfer the footage again, you might be able to get rid of it at the source. My camera allows me to turn off the date stamp as required, as it is not embedded in the footage, but in the data on the tape. If I want the date stamp to come through on the footage, I can do this, or I can turn it off. If you can do this, you will save yourself a lot of heartache.
i tried that but it wont let me turn it off because when he was taping the footage he had it on the hold time recording it on the video...... also i tried "croping it out" but didnt have any success and i need to know am i even doing it right ????? looked at it in the vegas 5 manual and did what it told me to do with croping but it didnt help any
either you have cropped it out or you didnt ... just use the pan and crop tool and crop out the area you want ..
you can also make a mask for that area if you want .. or use the v-dub logo away filter ..."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Originally Posted by mol3000
BJ_M-like the idea of the logo away filter. Will have to try that out and see how well it really works...
Remove Spoilers, Logos etc.
By illogical in forum User guidesReplies: 18Last Post: 17th Feb 2017, 08:25 -
Removing Logos using DeLogo vdub filter
By Matt D in forum EditingReplies: 67Last Post: 6th Apr 2016, 10:26 -
Remove Logos
By Bob740 in forum Newbie / General discussionsReplies: 2Last Post: 9th Dec 2010, 12:19 -
Logos in Credits
By ehmjay in forum MacReplies: 6Last Post: 13th Sep 2007, 21:27 -
2 Logos on a TV Station
By gll99 in forum Newbie / General discussionsReplies: 10Last Post: 23rd May 2007, 17:18
