im using dvdshrink version 3.1.7.6 and i used dvd decryptor to copy terminator 2 disk 2 to my hdd.
but now when i use dvd shirnk it out open the files.
i can open it with version 2.3 but i cant compress it with that version enough to fit on to dvd(unless i choose still pictors).
i did try using the re author feature once before but stuffed it up.anyone know what i can do.
RIP IN FILE MODE WITH DVD DECRYPTER then use DVD SHRINK to REAUTHOR.
__________________________________________________ __________
back on the pent 4 pc
If you dont find a suitable solution you could use version 2.3 and feed it through twice so it does fit onto a dvd
Hi all.
murderous, I'd suggest you have a look at the guides at DVDShrink.info.
They are very user-friendly and will show you if your method is correct.
dvdshrink
By Faerel in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2010, 23:07 -
SVCD2DVD when going to DVDShrink & DVDShrink Re-Author Problems in Vist
By pcandmac2006 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 23rd Jan 2009, 19:33 -
Once I've used DVDshrink, then what?
By craniac in forum Newbie / General discussionsReplies: 3Last Post: 18th Nov 2008, 17:17 -
VobBlanker vs. DVDShrink
By hech54 in forum DVD RippingReplies: 10Last Post: 19th Oct 2007, 01:39 -
MTR can't read DVD... READ ERROR: Can't Open IFO.
By strathq in forum MacReplies: 16Last Post: 16th Jun 2007, 23:04
