I'm assuming this is the best place to post this question. I've ripped a DVD with my PC and want to put it in the best format for someone to edit in Final Cut Pro.
1. Can the dvd player that comes with a Mac open a .vob file? Can a person just go to FILE>OPEN and open and play a raw dvd file (.vob file)? You can on a PC.
If you can, then that's great, as the person I am going to give this to can take it from there.
However, if that is not the case, then I need to find a format that will have the quality that is as close to a raw DVD file as possible.
I tried this process:
Ripped DVD>DVD2AVI>TMPGEnc (converted to VCD .mpg file)
When I did this, when I played it in Quicktime Pro on my PC, it was able to play it perfectly. However, when I tried to export it as a .mov file, there was no audio. I'm guessing it simply could not read the format.
2. Is there a way to import the original audio file (.wav file) into Quicktime Pro so that it would replace the audio file that is part of the vcd file? If so, how?
I had the Mac person try to use the vcd (mpg) file, but when they downloaded it from the net, it would only allow them to save it as a .mov file. So, when they tried to play the file in Final Cut Pro, it was able to play the video, but not the audio, as I had suspected based on the results with QT Pro.
3. If they were to change the file extension back to .mpg, would they then get the audio back?
4. How can you change the extension of a file on a Mac?
5. What would be the easiest way to go about converting my .vob file into a file that Final Cut Pro can read perfectly (highest quality possible, please)?
Sure, but not with the apple dvd player. Get VLC and you got drag and drop .vob viewingOriginally Posted by LABachlr
Questoin.. why not just do all this on the mac? The dvd can go to divx using Handbrake in a single click! or you can even go to .mpeg like you did for your step but what horrible loss of quality going to VCD!I tried this process:
Save will only be .mov He/she needs to choose EXPORT to have it do any sort of conversion.I had the Mac person try to use the vcd (mpg) file, but when they downloaded it from the net, it would only allow them to save it as a .mov file. So, when they tried to play the file in Final Cut Pro, it was able to play the video, but not the audio, as I had suspected based on the results with QT Pro.
not likely, but its worth a try?!3. If they were to change the file extension back to .mpg, would they then get the audio back?
click on the file name once and then move the mouse away from that name it will change to a typable field. Or you can right click on the icon, choose get info and go to Name and Extensions and rename it4. How can you change the extension of a file on a Mac?
cant help ya here, dont use FCP much. Look for FCPguy to reply5. What would be the easiest way to go about converting my .vob file into a file that Final Cut Pro can read perfectly (highest quality possible, please)? -
Very cool. Thanks. Hopefully that will work, but not sure. She needs to play it, and then somehow capture it with FCP while it is playing.Sure, but not with the apple dvd player. Get VLC and you got drag and drop .vob viewing
Can FCP read divx? Would going to .mpeg with Handbrake render quality loss, or are you only referring to my VCD version?Questoin.. why not just do all this on the mac? The dvd can go to divx using Handbrake in a single click! or you can even go to .mpeg like you did for your step but what horrible loss of quality going to VCD!
You're saying EXPORT in FCP, right? If it can't read the audio while it's playing, then it's not going to be able to export it.Save will only be .mov He/she needs to choose EXPORT to have it do any sort of conversion.
We'll see...not likely, but its worth a try?!
Cool. Thanks.click on the file name once and then move the mouse away from that name it will change to a typable field. Or you can right click on the icon, choose get info and go to Name and Extensions and rename it
No problem. Thanks for the help.cant help ya here, dont use FCP much. Look for FCPguy to reply -
sorry, earlier you were talking about quicktime pro, so i assumes you already knew that the source should be DV for FCP
i thought you were trying to export as DV from quicktime pro.
going about this the whole wrong way if you converted the dvd to vcd for edting - huge quality loss. Handbrake is a dvd2divx for mac, so its also going to be a quality loss
there was discussion in here on DVD editing in FCP check that out
if the mac has a superdrive, you would be better off just ripping and doing all the conversion on it rather than try to "save time" by doing some of the work on the pc simply because you will have to transfer the movie some how and were talking at the minimum 4.4 gigs of data here which would be on a dvd so why not just use the mac's drive do the ripping and editing on there?
just a thought
Issues Editing Skype's .MOV's in Final Cut Pro.
By macphoto in forum EditingReplies: 1Last Post: 14th Sep 2011, 20:18 -
Final Cut Pro: Converting FCP formatted .MOV to PC compatible format
By 6079 in forum Video ConversionReplies: 6Last Post: 23rd Sep 2010, 08:29 -
Converting a Final Cut Pro Motion template to a DVD Menu...
By Huntr777 in forum MacReplies: 0Last Post: 4th Apr 2010, 12:48 -
final cut pro - training on a DVD?
By Bansaw in forum Newbie / General discussionsReplies: 0Last Post: 29th Oct 2007, 04:04 -
final cut express and final cut pro 6
By ednarophati in forum MacReplies: 1Last Post: 16th Jul 2007, 10:05
