  1. I'm trying to use this program, but I can't seem to install it. The files i downloaded are in rar format and I also downloaded unrar and installed it. Unrar, tho it installed, doesn't seem to do anything. Any help in using this program on an xp sp1 system would be apreciated. Nyah Levi
  2. Get dvdauthorgui (or is that what you have?)
    I was able to use a program called "extractnow" to unpack the RAR. Got it from download.com. Then you end up with folder with the program and a subfolder or two. Just double click on the .exe to run dvdauthorgui.
    --Judd
    --Judd Volino
    Mar 2004
    London
    Why don't you just download Winrar?
    http://www.rarlab.com/
