Hello,
I have an xvid video with ac3 sound. There's no problem playing this file.
But I have problem getting the sound on my mpg.
First I've extracted the ac3 sound with virtualdubmod and use ac3 decoder to decode to wave pcm. But the problem is when I play the wave I'm missing 3 seconds of it. The xvid is 65.18 minutes but the wave is only 65.15 minutes. I've tried it twice and twice the same problem.
So I've searched for another way for the ac3 file.
Using besplit, besweet and besweetgui I've made a mp2 out of the ac3 file. But when I want to mux it with tmpgenc after 40mb it stopped saying illigal stream. And I've tried with 2 versions of tmpgenc but nothing works.
And the other thing is when I open the xvid avi in virtualdub or virtualdubmod there's a message: warning: nothing to output Bframe decoder lag.
I don't know what to try anymore as I run out of solutions.![]()
Can anyone please help me?
Sounds like you have a corrupted file. Try scanning for bad frames with Virtualdubmod and set it to delete bad frames. Save as a new avi with direct stream copy selected in the video menu and start from scratch with the new avi. I should tell you that fixing bad sync doesn't have a very high success rate so good luck.
just save it as an AC3 file,then run it through Besliced to fix it.
then mux them back together with whatever programme you want
SYNC PROBLEM: X264 AC3/DTS MKV --->>> Xvid with VBR mp3?
By Randm in forum Video ConversionReplies: 6Last Post: 30th Jul 2013, 17:57 -
MKVMerge problem , audio out of sync - says This AC3 track contains 227 byt
By PSPGamer in forum DVD RippingReplies: 2Last Post: 20th Apr 2011, 16:38 -
AC3 Sync problem out of MKV file
By betão in forum Blu-ray RippingReplies: 7Last Post: 9th Jul 2010, 22:30 -
Odd ac3 sync problem
By mayancastle in forum DVD RippingReplies: 7Last Post: 24th Jun 2009, 21:34 -
Sync issues after converting AVI (DivX 5/AC3) to MPEG2/AC3
By Greycat in forum Video ConversionReplies: 4Last Post: 25th Mar 2008, 10:24
