I just updated my system to Win Xp & the NTFS file system.
I captured some VHS video into a single 10gb file (using IuVcr & Huffy compression)
I opened TmpgEnc and tried to select & open my AVI file but Tmp gave me an error saying 'can't find the file or unsupported'
Tmp worked fine back when I ran Win ME and had segemented captures.
The 10gb file plays in Media player w/o any problems.
I used VirtualDub to extract a 1gb length segment & Tmpg opened that fine.
Any ideas on how I get Tmpg to work with large files?
thanks
That didn't work either, but I solved the problem.
I had to go into the environmental settings and bump up the Direct show item to the highest priority.
Can't Open a VERY Large MP4 File?
By ShadowfaxSTF in forum Video ConversionReplies: 3Last Post: 27th Jun 2011, 12:50 -
Can not open any file in TMPGEnc 4
By Soixante in forum Video ConversionReplies: 4Last Post: 8th Sep 2010, 09:56 -
can't open file in TMPGEnc
By windranger in forum Newbie / General discussionsReplies: 12Last Post: 18th Feb 2009, 10:25 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 14:23 -
ffmpeg choppy audio from large avi but not small avi source file
By cybertheque in forum Capturing and VCRReplies: 9Last Post: 13th Oct 2008, 16:38
