A newbie question. Can a DVB card ( I understand it decodes MPEG2 digital signal) decode digital cable? Or is it just for free-to-air channels?
dvb-c cards can decode digital cable tv:
https://www.videohelp.com/capturecards.php?CaptureCard=&dvbc=1&searchconnection=Any&pri...&Search=Search -
A good place to look for this kind of info, although a bit over the top most of the time, is the HTPC forum at www.avsforum.com.
-Suntan -
DVB cards can do digital cable. Sometimes, you need different software / firmware.
With the correct adjustment (LNB) you can ever receive DVB /T without issues.
pyrohydra: Depends what your cable provider follows there in the USA. Some of them follow DVB, so it migh interest you.
For the rest of the world (since North America is just the exception on this) this feature is very neccessary and 100% possible -
Off topic but...
WTF is with the color scheme on AVSForum? Absolutely hideous. Are they purposfully trying to drive people away with that shit? -
My guess has always been that they are trying to copy the colors of the inside of a movie theater... ...as I said, a bit over the top most of the time.
-Suntan -
see my full reply in the "Building a PVR that supports Digital Cable - Seeking TV Card" topic. (you are not allowed double posts ??)
ok, guys best i can see so far is http://www.dvico.com makes a QAM digital cable TV card that should work with un-encrypted digital cable. ...
(more in that reply)
HBO Kid
Demuxing (UK) Digital TV (DVB) Subtitles
By Salem874 in forum DVB / IPTVReplies: 7Last Post: 17th Mar 2012, 05:44 -
Re-editing digital on-screen graphic on MPEG files saved from DVB-T
By ANOther1676 in forum EditingReplies: 3Last Post: 17th Dec 2010, 18:23 -
HELP please Avermedia A316 Mini PCI-E Analog Digital DVB-T TV Card
By Jorocketoz in forum Capturing and VCRReplies: 0Last Post: 26th Jun 2010, 01:05 -
Moving from analog capture card to digital. Focus on cards with DVB-C (US)?
By ColKurtz in forum Newbie / General discussionsReplies: 6Last Post: 19th Aug 2008, 22:25 -
Quality of a DVB/Tuner card ; but simplicity of a Capture card.
By BATGAL in forum Capturing and VCRReplies: 3Last Post: 1st Oct 2007, 11:51
