I appear to have two DVD-RW coasters! Both were written to successfully with my Pioneer 107. However I attempted to use them again by first deleting the disk using DVDInfoPro before re writing. Now both disks don't even register as being in the drive!
Are these totally knackered? Is there anything I should be doing to stop this happening again?
BTW my DVD has been flashed with the latested hacked 1.13 firmware.
Results 1 to 9 of 9
When this happens to me, I stick the DVD-RW in the afternoon sun for about 20 minutes, then immediately go in and try to erase them. This method hasn't failed me yet.
ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
Tommyknocker - thanks for the suggestion but I get the same error - "no media is inserted"
SLK001 - you are joking right? -
No, I'm not. I have some Princo DVD-RWs that sometimes refuse to erase. The afternoon sun trick always works in getting them to erase.Originally Posted by blenkyICBM target coordinates:
If you know someone with a set top DVD recorder that uses -RW try erasing it on that. It's worked for me b4.
I don't have a bad attitude...
Life has a bad attitude! -
Have you actually tried using nero?
It might appear stupid, but you should not use cheap media for dvd-rw ever.
That is your problem.
OR try them in another pc.
I don't bother with them as 100 4spd dvd-rs + 100 cases (full size dvd ones) off www.blankdiscshop.co.uk are £29.95 plus they sell cheap enough branded dvd-rws too.
DVD Fab - DVD Shrink - DVD Decrypter OK, and disc is unusable?
By dledm in forum DVD RippingReplies: 7Last Post: 1st Jun 2010, 15:54 -
Windows 7 Upgrade Makes Some PCs Unusable
By deadrats in forum ComputerReplies: 88Last Post: 5th Dec 2009, 05:14 -
Orbit downloader - faded commands unusable
By chis@ in forum Video Streaming DownloadingReplies: 2Last Post: 29th Jun 2009, 02:58 -
Unusable results from VHS to Digital Conversion (Long)
By ZARTT in forum Newbie / General discussionsReplies: 11Last Post: 4th Feb 2009, 02:16 -
Burned an MPEG2, replicator says it's MPEG1 and unusable?
By First1 in forum Authoring (DVD)Replies: 4Last Post: 11th Nov 2007, 14:55
