MacTheRipper 2.0 is now released. It will show up on VT and MU as soon as our website is updated, but for now, you guys can get your copy here:
http://homepage.mac.com/wiseweasel/mactheripper2.sit
Or here if you have problems with the .sit file:
http://homepage.mac.com/wiseweasel/mactheripper2.dmg.bz2
Here are the changes in 2.0:
• Completely rewritten in Objective-C Cocoa to behave more like a Mac application
• New PGC mode for improved title and chapter extractions
• UOP disabling
• ForceRead mode for extracting damaged discs
• File size calculation in the various extraction modes
• DVD-ROM content extraction
• Compiled with GCC 3.3 for improved performance
• Countless bugfixes and performance enhancements
• Improved compatibility with a wider range of DVDs
• New and improved interface with innumerable enhancements
Many thanks to all of you that helped us test this and get ready for this day. Mac users everywhere will be very happy for it. As always, let us know if you encounter any problems.
[Edit] Added an alternate download link. [/Edit]
Results 1 to 30 of 58
I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté."
Many thanks to developpers.
The release version seems faster than the latest beta.
Congrats for the good job.
Oh yeah, that would be because we've managed to reduce the performance hit due to the progress bar. The next release will probably have even better (though maybe not as pretty) progress bars, with a minimal tax on CPU.Originally Posted by alkalineI like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté."
I just did 2 tries today with this new release. It works great!! Thank you so much for bringing this to the Mac world.
Powerbook 12" G4 1GHz, 512MB RAM, Superdrive
iMac 15" G4 800MHz, 768MB RAM, Combo -
Can MTR do everything that DVD Backup can do?
[if so, then I'll use this 1st, then DVD Backup, Yades, 0sex, etc. etc.] .....
THANKS SO MUCH! BTW [i emailed you about donations about last week, I'll be donating soon
it can do everything and more baby!Originally Posted by badtz
If you have not done so already, make the switch, it feels soo good
oh and i would re arrange your list like this
1st - MacThe Ripper
2nd - YadeX
3rd - OSeX
4th - dvdbackup
thats how much the app is out of date and old! -
I likes it Mikey. Speed seems up & compatibility, as always, excellent.
Only one problem. I often rip two DVD's at the same time to make compilations for my kiddo (ever notice how kid DVDs are 30-40 minutes long with 20 minutes of initial advertising before you can even access the menu). MTR 2 does not allow me to rip from both drives simultaneously, which I achieved previously by having two copies of MTR 1.5.x open at the same time. Now the second copy doesn't allow drive selection or nuthin' when the first is already ripping. -
I want a screenshot for my tools list.
MacTheRipper -
Here's a screenshot for ya:
I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté." -
No, thank you!Originally Posted by BaldrickI like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté."
http://www.cdfreaks.com/news/9833
Since CloneDVD can still copy, will MTR be able to do the same? -
That's been covered in this thread:
https://www.videohelp.com/forum/viewtopic.php?p=889136I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté." -
WW and Geezerbuttz,
great job! Love 2.0's interface and
speed and the bomberman face is
hilarious!
Question: I made a backup using MTR
without setting a new RCE.
I had tested it in DVD Player before
burning, and its working fine, and
in my standalone, it plays it fine.
So is it absolutley necessary to set
a new RCE if one is detected
by MTR?
Will there be something mysterious down the line
happen if I don't? -
I you want to assure that the disk will play in ALL dvd players , then yes...
Just coz it works on yours , does not mean that it will work on everybodies..
If RCE is detected.... remove it .... thats all you need to know.!!!!
GB -
Trying MTR 2.0 for the first time.
I insert the disk, fire up MTR 2.0 and MTR displays the message "READ ERROR! Cannot open IFO file". MTR then becomes unresponsive and I have to force-quit the app.
Assuming that it is true there is an IFO that can't be read, is there any way to determine which one? I can find no way to display this information. -
Could you contact us via email at mtr@wormintheapple.gr, and send us your Console.log and system.log files (just the last few lines of the latter)? Ask if you don't know how to locate these files. Thanks.
My reply to you bounced back, see private message... Here's the gist of it, though:
It looks like the crash was caused by Unsanity APE. We do not support MTR running with APE hacks. Either uninstall APE, or deactivate it specifically for MTR, as it causes serious stability problems.I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté." -
Are you talking about Unsanity "Paranoid Android" ? Right ?Originally Posted by WiseWeasel
Paranoid Android is an APE module. APE is Unsanity's Application Enhancer framework for hijacking applications' protected memory and inserting their code arbitrarily into them, wreaking all sorts of havoc. If you care about stability on your system, you should stay FAR, FAR away from all APE modules. You can disable APE on an application basis, but there's no way to only allow it for certain applications, for some idiotic reason. The best solution is to just not use their software.
Bomberman keeps yelling at me after I rip a DVD. I didn't know Bomberman cared about piracy, with him being a cartridge based character and all. Still, it rips my R2 I-Man DVDs in like twenty minutes, so its all good. Woo!
If it isn't broken, take it apart and find out why.
blog: deadsierra -
I have just recieved a message from WW that some IDIOTS in the DVD rip scene are pissed at the success of MTR , PISSED that i do not wish to share the code that I WROTE, so thay are going to petition the VideoLan Comunity to sue me for violation of the GPL ( the fact that i link to Libdvdcss , and use it unmodified seems to be irrelevent)..
Several people have attempted to get the Source that i wrote to see how things were done , and at every attempt i have rightly refused.Now they seem to be going to try underhanded sore looser methods to obtain what they have no rights to.
I will not be THREATENED , PUSHED , or BLACKMAILED by anyone,
As of now MacTheRipper is Dead.
You can all blame the greedy idiots for this.Talk about killing the software development scene.
We have ALWAYS declared what Libs we have linked to,It has never been hidden.
As a point of interest ( and as a paid user ) FFMPEGX uses GPL code althrough its code ( albeit linked into applescript) why has nobody threatedned major for the sourcecode? He even charges for the app , so it should be more relevant.
interesting enough thou .... as OSEX , DVDBackup all link to the same libs , I did not see any threats there , do you ?
I think anybody with average braincells can start to see a picture building up here eh!!
This is a shame as 2.1 was already well under way,And was slated to contain many new updates and enhancements.
I am very sorry to the genuine users who supported me during the development of this App , but I think you can understand my opinion, and why I feel I have to react in this way.
If Any body from form The VideoLan Community wishes to talk to me they may contact me throu WiseWeasel.
Geezerbuttz. -
hi geezerbuttz,
bitte, lass' dich von den diversen vollidioten nicht "runtermachen", die sind doch nur neidig auf deine supersoftware ...
bin schon gespannt wie dein MTR 2.1 wird, geht's überhaupt noch besser ... ???
liebe grüße
sascha -
Here's what Sherlock translated Sascha's message as:
Code:please, let ' you from the various complete idiots not "down-make", those are nevertheless only neidig on your supersoftware... are already strained like your MTR 2,1 becomes at all still better, geht's...??? loves greet
Boy, that sure was insightful... We don't all speak German, you insensitive clod!I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté."
MacTheRipper - couple of probs
By satcure in forum MacReplies: 3Last Post: 24th Aug 2010, 14:44 -
public domain songlist
By zoobie in forum AudioReplies: 0Last Post: 10th May 2009, 02:56 -
Invalid Public Atom
By Michael Boutros in forum ffmpegX general discussionReplies: 3Last Post: 22nd Apr 2009, 12:26 -
$35.00 for the movies (or how to rip off the public)
By FulciLives in forum Latest Video NewsReplies: 18Last Post: 26th Oct 2008, 00:20 -
MacTheRipper/Popcorn
By monieeka in forum MacReplies: 3Last Post: 21st Jul 2008, 02:39
