Strange problem here...
I encoded a VCD with a delay in the audio. To make a long story short, I cannot use the source video to encode audio and video again (I keep getting errors, it must be corrupt), so in order to fix, I have to split the tracks off of the VCD I already made, then remux using an offset for the audio. Supposedly TMPGEnc can do this...
But, when I tried to demux a normal MPG using TMPGEnc, it crashes every time... I can only assume it will do it again if I try to remux with it, even if another prog can demux... unless someone shows me how it can work!
Here's what I need to do, if someone can tell me how/what to use for each, that'd be helpful:
1- Convert VCD stream back to MPG file in Win 2000
2- Demux MPG to video/audio streams (or how to make TMPGEnc work)
3- Remux PROPERLY and PLAYABLY, and so I can make an offset to the audio while remux-ing (or how to make TMPGEnc work)
Thanks in advance!
Results 1 to 1 of 1
Extract Audio and video from Multiplex karaoke DVD and re author
By quebecLA in forum Video ConversionReplies: 1Last Post: 8th Jul 2011, 22:01 -
Replace audio in MPG video
By rdfarr in forum Authoring (DVD)Replies: 4Last Post: 29th Jan 2009, 17:22 -
Hi all, I need program to batch de-multiplex mpg files with 2 audio tracks
By mmdmmd in forum AudioReplies: 4Last Post: 14th Oct 2008, 15:57 -
Multiplex SD Mpeg with ac3 audio
By hartless in forum DVB / IPTVReplies: 8Last Post: 9th Sep 2008, 06:59 -
Multiplex with two audio streams
By heretic754 in forum AudioReplies: 2Last Post: 1st Jun 2007, 23:44
