    Belgium
    Hello Major,
    I'm encoding several mpeg2 files into mpeg1 but i have each time a first frame in a green solid color.
    My source is a ripped chapter with Yadex from a DVD. So i've a mpeg2 video track and an AC3 audio track.
    Next, i converted the AC3 track in MP2 track ("audio file to mp2 preset).
    Then i muxed the video and audio with "Mux as... DVD". (result = MPG)
    And finally i launched the encoding process with MPEG1 [.MPG] (mpeg2enc) setting (720x440 PAL if i want a 720x402 in quicktime!!!), Audio in passthrough (Encode Audio checked), Deinterlace filter (not a great result ), Decode with mplayer - PROFILE Generic MPEG-1)
    For each movie i got a first green frame...
    Any suggestion?
    Thanks,
    Toche
    Ti 867 MHz - 768 Mo - Airport - 10.3.4
    ffmpegX 0.0.9m [REG]
    Belgium
    Someone else?
    Belgium
    Ok, i've find the solution...
    The problem is "Decode with mplayer"
    With "Decode with mplayer", i've a first green frame and NO deinterlace
    With "Decode with Quicktime", i don't have the first green frame but the Deinterlace function doesn't work
    With both unchecked, i don't have the first green frame and the movie is deinterlaced
    Major, maybe it will be better to unchecked both by default when we choose MPEG1 [.MPG] (mpeg2enc)
    Toche
  4. I'm adding to my to-do list to check this issue. Thanks for reporting.
    Belgium
    You're welcome
