  1. Hi, I'm backing up the 3 Lord of the rings movies, from mexico, region 1, 4, when you first insert the dvd on the dvd player it shows a still menu so you can select which country you are, in this case it shows Mexico and Argentina.
    What I want to do is remove that flag menu and just go straight into the Mexican menu, is there a way to do that? I tried with ifoedit, i deleted that flag menu and it did go straight to the menu but it removed a "Seņor de los anillos" video intro, so how can I do that without removing the video intro.
  2. Greetings Supreme2k's Avatar
    Feb 2003
    Right Here, Right Now
    Try DVDRemake or Instantcopy.
  3. I can't do it with instant copy, I have the demo for dvdremake, but I can't do it with it either>
