please help me in buring my first VCD...
1. Download Friends Finale
2. Extracted and comes out to be .avi
3. Can play in Windows media but can't burn to disk.
4. Trying to use Nero Video CD
5. Added Friends Finale.avi to file to be burn.
6. can't seem to burn.
what am I doing wrong? do I need to convert .avi to .bin and .cue if so, what are the steps? thanks
Results 1 to 17 of 17
i use Nero 6 Express...
in nero express 6, choose Videos then video cd.
add the avi file and click finished...nero 6 will reencode the avi file to vcd format (tmpgenc is a better encoder though)
then click Next, next, then click burn...hacking the Net using typewriter :D -
I did what you said and I get "Unknown error in the Video MPEG encoder"? and it was at 3% encoding video in Nero 6....thanks
Remember jimmalenko, Baldrick has said that TV shows are not warez
Me =
My apologiesOriginally Posted by johns0
That's right, I remember him saying something along the lines of "I do it, so it's sort of hypocritical to stop anyone on this site doing it" or words to that effect. Check out this thread for the response from the masses. Also check out this poll.If in doubt, Google it. -
Of course, you could always just buy the DVD
. I think I got mine on sale at Fry's for about $8, and you get some extra stuff with it.
That's always my philosophy. If you have the time to struggle with converting/authoring/burning something that's available commercially, then work the overtime at your job and buy it. You'll get better quality plus extras (including a nifty case and cover).
That error sounds like there is something fooked up with your computer. It is an Operating System message, sounds like Win98. It makes it easier to sort out problems if we know your computer specs. Please take the time to fill out your Computer Details in your profile.Originally Posted by nextTOkinIf in doubt, Google it.
...especially if it was only $8. By the time you d/l, convert author and burn, you are working for about $4 an hour. Quality of d/l is always a concern too.Originally Posted by Supreme2k
Anyway...
The error you describe is a OS error, typefied by Win95 and Win98/98SE. For future reference, it is helpful to us if we can look at your computer's specs. Please fill these in under Computer Details in your profile at your earliest convenience. Generally a defrag can fix problems such as this, but on the odd occasion a reinstall is necessary.Originally Posted by nextTOkin
Once you have the AVI, it would be wise to check if the file has VBR audio and if it has bad frames. You can do this using VirtualDub-mp3, and using the guide here. If you have VBR audio, a message will come up when you open the AVI asking if you wish to convert it to CBR. Say Yes or OK to this. Follow the guide to check for bad frames.
Once you have your "new" AVI, start TMPGEnc. Close the wizard if it opens. Load either the PAL or NTSC VCD/SVCD (whichever one you want to do) template and load your AVI. If you need to tweak some settings, load the unlock template and tweak away.
Click the start button and let TMPGEnc do its thing. Once finished, use Nero in Express mode. Follow the screens to do a VCD/SVCD and add the file that TMPGEnc created. You don't mention if you are using a newer or older version of Nero so it is hard to describe word for word the steps you need to take.
Again, All this to save $8 ??? I guess if it is a hobby, then all power to you.
You must be patient and willing to learn (and read) if you want to get anywhere in the video world.
See how you go.If in doubt, Google it. -
Great ! Thanking you...Originally Posted by nextTOkin
XP putting up that error, eh ? You might want to reinstall TMPGEnc, because that sort of thing shouldn't be happening, although ti does indicate that there might be something wrong with the AVI file, as I mentioned in my previous post.If in doubt, Google it.
Jerked images upon buring DVD
By Ilovm in forum Newbie / General discussionsReplies: 1Last Post: 26th Jun 2011, 11:28 -
Help a newbie out buring AVCHD.
By flyin-lowe in forum Newbie / General discussionsReplies: 5Last Post: 3rd Nov 2010, 12:47 -
Would really love help with buring videos to Dvds.
By Freakypenguin447 in forum Newbie / General discussionsReplies: 10Last Post: 9th Oct 2010, 21:16 -
MS Movie Maker and buring DVD
By ccm in forum Newbie / General discussionsReplies: 2Last Post: 6th Aug 2009, 17:49 -
Buring video to DVD player
By BVG in forum Newbie / General discussionsReplies: 3Last Post: 17th Jan 2009, 14:58
