Hi,
I have some mpegs I would like to compress. The mpegs are 22 megs for 2.5 minutes. I was wondering if it is possible to compress them more. What programs should I use? How much can you decrease the size of the mpeg? I would also like any other ideas for help you might have. You can email me or answer here thanks.
yea compress them to an avi file which is much smaller if u use a codec that really compresses like divx....use virtual dub
try also at the follow site :
http://www.geocities.com/mpgtoasf
or try to save AUDIO to MP3 .. smaller size of target file !
Thanks Goldenaxe4000 and eatin samiches for lunch
One other thing is there a way to compress them more if I want to keep them mpegs?
there is no way to "compress on the fly" any mpeg ...at least not that I know of....the only way is to re-encode with a lower bit rate.(bit rate calculator)...and also sacrifice quality..OR...split the mpeg and use two 33 cent cdr's....thats what i do.
If you want to keep the mpeg as an mpeg but just reduce the size use Flask to alter the bitrate to what you want, the less the bit rate the worse the quality suggest 1000 for vid and 128 for audio you can go lower but it gets worse. Also try dvd ulead movie factory, it has a good way to see what your original mpg properties are e.g mpeg 1 1150 bits\sec video 224 audio. Hope that helps
Joining more than 2 mpegs...
By artphotodude in forum ffmpegX general discussionReplies: 2Last Post: 30th Jul 2011, 10:33 -
Do I need to Compress the Data?
By Seanna in forum MacReplies: 10Last Post: 17th Mar 2010, 14:32 -
Compress some files
By alintatoc in forum ComputerReplies: 5Last Post: 24th Feb 2009, 05:14 -
Can i compress a
By YOURCONNEXX in forum Video ConversionReplies: 4Last Post: 9th Dec 2007, 13:03 -
how do I compress DV videos into good quality mpegs?
By bball_1523 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 10Last Post: 1st Jul 2007, 17:22
