Hi,
Friend of mine gave me a DVD he brought it from asia. I can't play it at my dvd player, but I can play it in my PC. Is it because the PAL/NTSC different or the region different.?
thanks.
its because its a different region. it may be PAL, im not sure about what system asia has.
It might also be because it is poorly copied. A friend bought a pile of these a few months back. I took four of them home. Only one would play on my player (a 4 year old pioneer), but all would play on either the PC or on newer (and cheaper, more compliance tolerant asian knock-off) player.
They were either compiled out of spec, or simply poorly duplicated. That is the problem with bootlegs - quality control just isn't there.
WIERD DVD data disk problem
By bruinflight in forum Newbie / General discussionsReplies: 24Last Post: 24th Sep 2009, 23:53 -
Playing External Subtitles with a Blu-Ray Disk????
By BlackDevil15 in forum Software PlayingReplies: 3Last Post: 30th Dec 2008, 10:44 -
Playing DVD-RAM Video Disk On PC
By Rayvyn007 in forum Software PlayingReplies: 2Last Post: 23rd Jan 2008, 13:01 -
Playing AVCHD DIsk
By nirbhayn in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 29th Oct 2007, 09:00 -
Format for recording, playing on different unit, then re-using disk ???
By TVTimeShifter in forum DVD & Blu-ray RecordersReplies: 16Last Post: 30th Sep 2007, 18:21
