  1. I want to make installable CD of my operating system to install in my another computer? I lost my product key any CD.
    Jan 2004
    Mozambique
    If you had a duplacate system you might be able to clone the the OS to a new drive but I know of no way to make an instalation CD out of an existing system. However you might check out Bootdisk.com.. Good luck
    Big Government is Big Business.. just without a product and at twice the price... after all if the opposite of pro is con then wouldn’t the opposite of progress be congress?
  3. Originally Posted by niskalsoham
    Try this: http://www.nu2.nu/pebuilder/
    also I think I've read before that the product key is s/b buried in the registry.....
    makntraks
    In the theater of the mind...
    It's always good to know where the exits are...
  4. Get Everest Home Edition (free) and it will tell you what your product key is.
    http://www.lavalys.com/index.php?page=product&view=1
    Alternatively, with no CD, what you're talking about is illegal.
    You can use something like Norton Ghost to make an image disk, and try that on the other system, however, unless it's identical it probably won't work.
    Cheers, Jim
    My DVDLab Guides
  5. With windows XP the Product Key is buried in the registry (or somewhere). If found a utiity online that allowed me to 'extract' that product key from my existing install. I needed that about 2 months ago when I was in the same predicament in that I lost me key
