  1. I should stick to gardening.
    I've bumped into yet another codec that isn't straight-forward. What is ".xvid.mkv" and how can I play it and dump it to CD/DVD?
    QuickTime player 6.5 won't touch it.
    VLC opens it and plays the video, but only plays one of the 6 audio channels (and not the main one).
    Seeing as it is an XVID file, I downloaded and theoretically installed correctly an "XVID Delegate Component" that purportedly allowed QuickTime to access XVID files, but that didn't make any difference with this XVID.MKV file.
    VLC info on this file:
    Stream 0 (Video):
    codec = XVID
    size = 640x340
    Stream 1 (Audio):
    codec = mp4a (English 6 channel)
    sample rate 1 22050
    There are also additional streams for Japanese audio and English/Japanese subtitles.
    Under "file information", the muxing application is listed as:
    "libebml v0.6.3 + libematroska v0.6.2"
    writing application is listed as:
    "vkvmerge v0.8.1"
    Any clues or tips appreciated.
  2. Member galactica's Avatar
    Jan 2003
    Under Gateway to Midwest
    does mplayerosx play it
    if so then you can use that or possibly even convert it over to a more acceptable file type for the other players
    where did you get a file like this is the question on my mind
    Apr 2004
    I believe mkv is the Matroska container extension. I would expect both VLC and mplayer to play it, failing that, I think ffmpegX accepts matroska, perhaps you could demux the mkv and remux as avi.
  4. Originally Posted by galactica
    does mplayerosx play it?
    Nope, I already tried that. My apologies for not including that info in my original post.
    where did you get a file like this?
    It's an anime file, the first one I've seen.
  5. Originally Posted by fugu
    Yes, it is.
    As noted in my original message, VLC plays the video properly, but only plays one of the six audio channels (and one of the back ones, at that). mplayer is a no-go.
    I tried ffmpegX with no luck. However I just checked and there has been a minor update since the version I have, so I will try that one.
    Apr 2004
    Apparently, a special version of mplayer is req'd.
    http://matroska.free.fr/downloads/downloads.html
    There are also some CLI Utilities to work with mkv
    http://www.bunkus.org/videotools/mkvtoolnix/index.html#dlinst_macosx[/url]
  7. Member galactica's Avatar
    Jan 2003
    i love it
    For playback of matroska files on MacOSX you also need a special version of Mplayer
    wonder if OSX is the only one with special versions of things
  8. Master of my domain thoughton's Avatar
    England
    You can demux it with mkvtoolnix. It's command line only but very easy to install/use. There's a link on my website if you cant find it on google. Also very fast (couple of mins for 700MB mkv file) and you'll end up with the xvid and whatever audio it contains without the silly mkv container. Once you have those it's easy.
    Galactica why do you always wonder where we get our files from? What does it matter to you? And please don't feed me some line about crappy encoding on PCs.
    Tim Houghton
    WebsitePhotography
